2009 S550 4Matic,1986 560SEL, 1986 560SEL, 1992 500SEL, 1999 S500
Capacitors do indeed go bad. Overvoltage, possibly from a defective charging system can damage them. An electrolytic will explode with a high enough voltage. They all are stamped with a working voltage rating. Anyone with an old Predicta TV from the fifties will know that recapping the chassis is a normal restoration step. Abit, a manufacturer of computer motherboards, has been dealing with a class action lawsuit concerning bad electrolytics on their mobos which LEAK the electrolyte, causing a no-boot situation and can corode the circuit board. Luckily none of my Abit boards are defective. Even though they are "solid state" devices there are still physical forces involved inside them. There is slight movement of the layers and heat build up as they charge/discharge. Plus the hot/cold cycles of normal operation take their toll, especially here in frozen Michigan "Winter Wonderland"!!
I've got the same problem with my dash and will look at the cap in some warmer weather. A larger value would be good. There are different qualities out there. Rat Shack ones will work but you may want to look for better if there is an electronic store near you or through DigiKey. Remember, there is bargain basement quality and then there is Mil Spec.
