1985 300D Gone 1985 230CE Perfect, 1984 300TD Driver, 1981 300TD Bad engine
1984 300TD
The vacuum system works good. Good brake and locks work fine. One thing that bugged me is that it took what seems like a long time for the engine to stop after the key is turned off. About two to three seconds. It shakes bad during this time.
I pulled a vacuum reservoir tank off a gasser and installed it and a check valve as close to the vacuum switch on the ignition as possible. The engine now stops nearly instantly. About a half of a second. Much nicer.
How long should it take to shut down?
Am I compensating for another problem or have I made a design improvement?
