1985 380sl
Hey Team! Any thoughts and ideas and wisdom on installing a new rear view mirror on my 1972 280SE 4.5? Thanks!
1998 SL500, 2010 GLK 350, 1972 300SEL 4.5, 1971 280SL, 1970 300SEL 6.3
I have done this. Suggest you tape over where you will drill your holes so you will not chip the paint much. Start with small bit and move up to larger ones. You may want to put some paint or preservative around the hole so it does not rust. I positioned it such that it is symmetrical with the driver's side mirror.
Will
Immoderately Caffeinated/ Vintage Moderator
T5
1985 380sl
Are you putting plastic inserts in the holes to hold the screws or what?
