1982 240D M/T White
I would like some specific answers on installation.
The Optima 75-35 has the poles (+ and -) reversed and has both standard SAE posts and GM side bolt posts.
The reversed poles will looks ugly once installed and requires longer battery cables.
How long are original M-B cables, positive and negative ?
How long are replacement cables ?
I have thought about screwing in "charging posts" onto the GM side posts (at least for the + pole). Are brass or lead screw ins best ? (These posts allow standard cables to attach).
Should the battery be secured "on it's back" with the top posts pointing out ? Or is any other mounting reasonable (rotate battery 90 degrees with + post out and - post underneath ?)
Any experience and advise would be welcomed.
Best Hopes,
Alan
1959 220S cabriolet, 1983 240D original owner, 1999 E300 turbo diesel, 1988 560SL, 2003 SLK320
Buy the Optima with the reversed terminals. It's called a 35R. That's what generally works best on most Mercedes.
Len
Mercedes 600
I recently bought at Optima 35 for my Porsche. What a difference in weight!
1982 240D M/T White
I just installed it this evening. Laid it on it's side with the SAE posts facing out (positive towards engine) and GM "side" terminals facing up.
Battery was 1/8" wider than stock Group 49 battery so the clamps were ground down 1/8" inch to fit (no edge to clamp onto though). Also secured with bungee cord (may be updated).
The clamps stop front-back motion and even side to side motion, but limited up-down motion so I added the bungee cord.
Positive test circle (dime size section of lead or ? exposed on same side as SAE terminal) was covered with orange silicone for insulation.
Terminals bolted on easily !
Plan to add secondary ground wire from GM terminal now on top (add charging post) to engine strut.
A bit odd looking, but very functional !
Optima batteries can be mounted in a variety of ways, including on their side.
Best Hopes,
Alan
'77 6.9, 74 240D, 96 Ram 5.9L Cummins
I like those Optimas. I run them in all my cars although they are smaller but they have plenty of cranking power even when they have been drained considerably.
