1 - 1 of 1 Posts
1991 560 SEL black/black
So I'm in the final stages of putting together the engine compartment in my '91 560SEL, I have the engine/trans bolted in, intake/exhaust manifolds installed & torqued, all driveline accessories in (PS, AC, Water pump) but while I was installing the wiring harness I noticed there is a small wire going to the starter that I can't figure out where it goes; any help? Also, getting the trans dipstick back on is proving to be kind of a PITA (I know, should have put in on when the engine was out....).
Also, where does the throttle position sensor (above vibration dampner) connect? One more - where does the plug from the throttle body connect?
1 - 1 of 1 Posts
