ML500, C280S, 300TD
I saw somewhere a pictorial on the replacement install of the American Nav with Command. I bought the command but I have no vlue as to what C1, C2, A ... etc connectors are.
Could you please point me in the right direction.
Brabus ML 270CDI
here is the command rear info!
The standard Mercedes head-unit’s have various connectors: -
A Power connector
B Speaker connector
C Mercedes-benz special connector (CD power, CANbus etc)
D2B D2B fibre optic connector
D Antenna connector
F iverse Antenna connection (on Audio-30 for instance)
COMAND has the following connectors: -
A Power connector
B Speaker connector
D Main Antenna connector
F Diverse Antenna connection (small coax connector)
E GPS antenna connector (square grey coax HRS connector)
C1 Mercedes Benz 18-way high density connector (control signals)
C2 Mercedes Benz 8-way high density connector (TV RGB, CD power)
Note, if you car has the Digital BOSE system, connector B will be empty as the amp connects to the head unit via the D2B fibre optic connection.
Brabus ML 270CDI
Lanny,
I collated the various information to be found on the internet on the subject "ML (W163) Command Install" into a single document!
PM me and I'll give you the info to download it!
cheers
ML500, C280S, 300TD
I tried to PM but could not get it going. Here is the content of my message:
I am sorry I did not respond but I got involved in too many things...
The unit was installed finally by Blaupunkt guys here in Prague. It works but it takes for ever to get its position most of the time. May be this is beacause of the internal antenna. I am thinking about having an external one installed as was on my previous vehicle.
Thanks again.
Lanny
