Maxbumpo,
Have you done a visual static cam position check? Takes about 15 minutes.
I've also heard faults can be caused by faulty cam sensors as well, but I dunno your particular situation.
I'd be interested as well if a borescope can be utilized to scope out balance shaft sprocket condition.
My 2006 E350 is within the bad range, but it's still fine with 146K miles. They say only 10-30% of engines within the bad range are actually faulty, as MB apparently had several suppliers of the sprockets so not all had the manufacturing process wrong. 🤞
