Car: E320 97 Japanese spec
I had a warm start problem which seems to be due to a leaky injector. I replaced all six injectors with used ones and the car starts as normal now (six injectors with their fuel pipes and valve are replaced).
Is there anyway to check and identify which injector is causing the engine to flood and resulting in warm start issue.
(note: before changing the injectors, i changed the MAF, plugs, CPS, used injector cleaning material. all of them have failed to solve the problem)
