Inside door panels.
1042 Views 5 Replies 3 Participants Last post by  W140Gill
Hi everyone, I'm really glad I foungd this site.
Does anyone know how to remove the drivers door panel in the 140? I have a 92 400se. I know a special tool is needed for the wood inserts. What is it, and where can I get one?
Thanks,
drk grn.....[8)][8)]
W140 S class, E31 850Ci, XC90 Exec AWD geartronic
why do you need to remove the panel?
Special tools are not really necessary - just a smal...
Special tools are not really necessary - just a small flat tipped screwdriver,a pin to pick out the screw caps, a cross headed screw driver and some brute force.
Which panel are you removing? and why? Most door lock work can be done without removing it.
Are your seats electric or manually operated?
2007 s550
Insid panels
I'm trying to remove the drivers side panel, and my seats are electrically operated with memory. I need to remove the panel because my locking mechanism will not work with the key on the drivers side, but it will work with the keyless entry. Plus there's a rattling sound coming from the door that is very annoying.
Thanks for any help you can provide.
drk. grn.
Re: 600se rear door trim
How do you remove rear door trim on a 1993 600se? do I need special tools, window glass has dropped into door, dont know what the cause is! many thanks
practically identical to removing the front door card. See my earlier post. You will need to remove the door ashtray and screw first.
