I am having oil leaks under the oil pan and all over the bottom of the engine, i also have tranny fluid leaks out of a black rubber in the front of the car, I know one of the leaks is a head gasket cover that's whatever but the other ones have me worried because it's leaking so much. anyone know what's up?
Transmission fluid leaking out of a "black rubber" in the front of the car? A black rubber what? All I can think of with the info that you've provided is the pair or rubber hoses that connect the transmission to the radiator transmission fluid cooler tank. They're not expensive or hard to replace. You'll need 17mm and 19mm open end wrenches IIRC.
