Well, I'm somewhat new to diesels (but not to turbos), but it is my understanding that the...
Well, I'm somewhat new to diesels (but not to turbos), but it is my understanding that there is no such thing as a "lean" condition in a turbodiesel, at least where it will cause a problem. Since the fuel is injected at the point in the compression stroke where you are past the point where detonation is a problem (you don't ever compress a fuel mixture before ignition), you can run them "lean" and you will just experience a drop in power.
So I would say you are probably ok to run it as is.
