1 - 20 of 40 Posts
2002 S500, 1993 Nissan 300zx
Does anyone know how to clean injectors that are removed from the engine?
Do they have to be pressurized?
Or will a good solvent tank do the job?
Or is this not even possible?
1973 450SL
lot of good info if you search for cleaning injectors..
i followed a couple of threads and purchased a cheap ultrasonic cleaner designed for jewelry and used injector cleaner to clean ours and it worked great...
also used an old electric fuel pump i had lying around and same cleaner with a 12 volt battery to "flush" them as well..
good luck and do not use wife/girlfreind/moms cleaner for this job.....don't ask how i know
Right On
Very cool and helpful info. I am looking for one now on eBay. Thanks guys!
Any other ideas, feel free to share.
PS: Thanks for the wife's cleanser tips. Mine is a neat freak...she'd have me using Windex on them in no time. I can hear it now: "Why do you need to use that smelly stuff? Use some Windex instead...it smells pretty".
93 300E 2.8, 79 450 SLC
Is it better to remove the injectors to clean? I just used bottle Shell/Chevron fuel injector cleaners.
1973 450SL
i have done that too on different cars, but that did not work on the benz...
so while i was replacing the injector seals(highly recomended) i followed the advise of others and did the cleaning as well..
well worth the effort...
and don't forget to replace those crappy old hoses also...
Re: Is it Better?
My car is having issues that will require me to clean them off the motor. A jab of techron won't do it...but I wish it would.
R/C107 Moderator
I did what Tork'd did and checked the spray pattern and volume while I was at it. Of course our injectors are so expensive that anything that can be done to save them is worth it.
Injector Cost
Yep. About $40 each that includes the seals, etc.
I am gonna try the ultra sonic methid and the blast cleaner through them with a fuel pump method.
R/C107 Moderator
I was referring to our having d-Jet injectors. List about $250.00 each. I have seen them as low as $166.00 each.:crybaby2::crybaby2:
2010 Mercury Milan Hybrid, 1993 BMW 325i convertible
R/C107 Moderator
I thought they could not be rebuilt or refurbished. But I once thought the earth was round or ovate. Either way it is a good price if they have been tested and flow checked. Plus Germanstar is guaranteeing them I hope.
1981 380SL - Lorinser bodykit w/16x7 LOs - AKA "Frau Blau"(Lady Blue)
Uhh, must be totally different than mine, I replaced the injectors, holders and seals for less than $250 from autohausaz?
Hey Leer - $245.20 from autohausaz.com - 8 Injectors, w/seals and holders. freight included.
And mine runs like a champ now, BTW!!
1 - 20 of 40 Posts
