1 - 13 of 13 Posts
I recently had my outside temp reading mess up somehow. Some parts of the digits are missing, is this something that the warranty would cover? Another problem is when i turn on the heat at about 1000-1200 Rpm the car makes a humming noise. When i turn off the heat its fine. Also, my passenger side headrest is no longer functioning at all. Would this be covered under the Extended Starmark warranty (2000 CLK320)? where can i find out what the extended starmark warranty covers and what it doesnt?
thanks in advance for reading
2000 CLK430 Coupe
1) Temp Gauge Reading: bad instrument cluster...do a search; tons of posts on this. May be Starmark covered, if not it's about $900.
2) Noise when heater is on: no idea.
3) Headrest/Starmark: Call MBUSA or your dealer
Friendly advice: you need to give people time to respond to your posts...more than 7 hours, especially on a weekday. [;)]
Good luck.
sorry about that.. but thank you so much for ur reply. i was wondering if i can email and ask mbusa if a specific item is covered, because the dealer wont tell me until i get it diagnosted from them and sign the paper with the possible diagnose fee $250.00.
· BenzWorld W208 Host
I can only advice regarding the temp gauge. On my friends 2002, CLK 320 convertible his temp gauge started to do similar things to what you are describing, after three months it started working as normal and has been fine ever since. CLK's have electrical gremlins so dont worry too much. Good luck
1999 clk 320
call 18002220100 tell all the problems you have but if you tow it ,tow it on your own expense because mercedes will charge you,Tow it to your nearest merecedes dealship.They will fix and the problems under starmark even the cluster I just had mine change recently under starkmark .
1 - 13 of 13 Posts
