W140-S 320-1995
Hi everybody,,,,,,,,
There is a noise from in-car Temp Sensor , like tik tik ..!!!
my Q is: what is the problem exactly??and How I can fix it??
Before replace the item,take it out and spray it with a lot of contact spray/or wd-40 but i avoid to use it/ spray around the sensor but not directly on it end inside the electric motor. A lot of dust and black things will come out. After that blow it with compressed air or leave it alone for a hour.Reattach it and try again - probably the noise will be gone and the sensor will work corectly. This procedure solve my problem and save me 120E ;)
W140-S 320-1995
Thaaaank .... It's good & easy Solution :thumbsup:
