1 - 1 of 1 Posts
2003 Mercedes SL, 1964 Corvette StingRay Sport Coupe, 1992 Mercedes 300 SL, Porsche 911 Twin Turbo
Just a few words so you dont do the same mistace as i did.
When changing the lights bulbs for the interior(map light/mirror)
be aware that the bulbs are halogen and and not regular light bulbs so they need to be replaced with the same 5 W halogen bulbs.
I found this out 10 minures ago because i used regular light bulbs when changing a couple of broken bulbs and all of the light/bulbs in the instrumentpanel lit up like a christmasthree flashing like crazy and only the temperature gauge was working
I immediate had a feeling that the problem was caused by that i had used the wrong bulbs(regular non halogen)
Replaced the map lights with 5 W halogen bulbs and checked the fused panel(i fuse was broken)changed the fuse and everything works as it is supposed to do
1 - 1 of 1 Posts
