1987 420 SEL
I always hear that you should disconnect the coil wire when doing oil changes. Now, I need to know exactly which wire to take off. Is it the wire coming from the distributor (the center wire) that leads to the coil.
Or,
Is it the two wires that are attached on top of the coil itself under that black cap. Please advise as soon as possible cause I need to change my oil this evening. Thanks.
1991 300 SE
See Jonathan’s post, I like that idea…
http://www.mbnz.org/forums/forums/thread-view.asp?tid=1202938&posts=8&hl=coil+oil+change
…and see your pm.
1987 420 SEL
I'm the originator of that post and I forgot Jonathan had posted posted that response. I must still be sleepy...Monday morning. Thanks anyway though. Better to play it safe!!!
