According to the algorithm, if the coil resistance is under spec, you should replace it. Perhaps there's a short circuit in it that's causing the failure to read the code.
You'll know for sure when you replace it.
According to the algorithm, if the coil resistance is under spec, you should replace it. Perhaps there's a short circuit in it that's causing the failure to read the code.The resistance of transponder coil is 3,2 not 5 ohms. Is it critical and can trigger "Start Error" ???
How can they be mismatched if the truck was running fine at one time? Maybe I don't know what you mean.Transponder ring and box immobilizer are connected with 2 grey wires. Can they be separated and mismatched
From my experience, yes, if you can find a working Ring...but best to find the whole set. It's easy to remove as mentioned earlier and easy to get to, in case you need to show the junnkyard over the phone or email. The Ring acts as a signal pickup and the box act as an amplifier.I mean can I mismatch them if they will not be available as a whole unit from whatever source ?? Like in my case I have defect in coil... unless I don't understand and they must be a unit... There are junk yards in Panama, but ML is an extreme rarity.
With lights as in headlights or dash lights? I would assume you meant the headlights...and that's different.Thank CGL. No, there is no beeping sound when I open driver door with either keys in. There is beep with lights on...
good point!Gentlemen, I suspect that the beeping keysense feature is specific to US models, and the OP's ML270 isn't equipped with it. Mine doesn't have this either, or a burglar alarm or panic button.
Have you verified power at (N26/4 pin 2)?Gentlemen. Now with key-sense feature out of the picture I left with DAS ring with 3,2 ohms resistance rather than 5 as most probable culprit of Start Error message and I need a replacement . Is this right conclusion ???
Hi. I measure resistance inside the ring between 2 grey wires possible ends of coil same wires that enter immobilized. Sorry can't give diagram...Have you verified power at (N26/4 pin 2)?
where are you measuring the 3.2 Ohms (give me diagram pins please)
