450slc5.0cab 280sl5sp 280se4.5 500seAMG +250seStkW108 350sl4spdX3 500secEuro 300sel5spd R+C107galore
Last night I sold my 1992 500sl, and my saga comes to an end. A few things I discovered / hypothesized while getting the car ready for pickup:
First potential buyer was a scumbag, me thinks:
I went to charge up AC so the guy knows it works, because last summer it was nice and cold for a while, and I'd only done a single can charge of r12. But after a guy took the car for a ride while I was embarking on the top hydraulics fix, the guy said the AC is blowing warm. I figured the AC simply lost its charge, and my decision was to not charge it again with r12 since it's bad for the environment, and if it leaks, it should get r134a conversion. Well, that never happened, and the car was about to leave. So I figured I better put a can of r12 in. I hooked up my r12 gauges and tapped a can, but the compressor wouldn't turn. I had about 60-70 PSI on the low side that normally doesn't exceed 25psi when the compressor is running. WTF? So I google and discover that step 1 is to check the B fuse. MISSING! And there's a white fuse sitting in the extra section. So it's not like I stole the fuse. Hmm... WTF? Now wait... the AC was working fine when that guy took the car for a ride, and came back blowing warm. And that guy has since purchased 3 r129 cars. Wow. Scumbag me thinks. As soon as I put the fuse in the Air worked fine. Wasted a can of r12, but topped off the system and got the majority of it into the system, with high side pressure upped from about 155 to 200+ PSI. I feel bad for the environment, but I learned a lesson.
What else... I did lots and lots of cleaning.
I bypassed the windshield washer reservoir heating element since this car is going to Georgia and Florida. I had confirmed that the thermostat on that heating element was still leaking after I had cleaned out the washer reservoir.
I hooked up the subwoofer amp again and learned how to set the bass at different frequency levels so it sounded nice instead of rattling all the time.
I popped the nicest hardtop I've got on the car and vacuumed the wind blocker.
I removed the floor and trunk mats and washed them as best as I could.
I tightened the belt tensioner and stopped that damn belt squeal on startup and when the electric takes a load or the AC clicks on.
All these things that I never found a full day to invest in the car for got fixed right when it was time to sell. The urgency and knowing the money is coming creates the urgency that my wife respected. That's the difference between a toy and a job I guess.
The car went right up onto the trailer and is probably driving south right about now. The weather was horrible and rainy. So I didn't take any pictures, but it's gone.
The r129 was the newest of any cars I've refurbished, and it certainly was the most time consuming and complicated. And mine was the early simpler version. The last chassis that I have owned in MB and said "never again" to was the w114. The carbs and rust on that chassis with the limited up-side value will probably keep me away from those cars forever. R129 have great value in parts, but the sale prices are in the dumps because there are so many with so many small (or even large) problems. Top hydraulics, cooling systems, crappy sideways distributor caps. Man. They are a lot of car for the money, but I think it will be a while before I return to one. I now can get back to my r107 and w108 cars, and maybe my w126 AMG project. The w126 and w108 may be equal wastes of time. Perhaps I should find a good w109 if I want to waste my time on that chassis. And the 1985 500se is probably an equal waste, but I've fallen into those traps. I finally got my leg out of the r129 without having to hack it off. ;-)
