1 - 13 of 13 Posts
Ignition replacement
The electronic portion of my ignition is bad. No response when you turn the key to the start position. Everything else functions as it should. From what I have read it is pretty serious surgery. Any ideas?
thanks
Ben
· IR MODERATOR
1996 Volvo 855GLT, 1993 MB 190e 2.3 8v, 1998 Subaru Outback SUS, 1991 BMW 525, 1998 MB C230
what happens when you turn the key to the first or second position? all you need to so is remove the cluster and reach back there and unplug it and unscrew the ele part of teh switch with a flathead bit. to get the switch unplugged the key needs to be in an in kp1
Discussion Starter · #5 ·
ignition replacement
The key in the 1st and 2nd position function normally. Everything lights up as normal and you turn the key to start and nothing. Not a click nothing. Can you get the electronic portion out without having to pull the steering wheel? Do you have to remove the lock cylinder to get the electronic part out? Thanks for everyones help!
Ben
1985 16v
· IR MODERATOR
Ben
1985 16v
can be done with out pullin the wheel. but are you sure the starter in your car isnt just bad or a bad battery?
Discussion Starter · #8 ·
So the car is in storage for 9 months out of the year- it does not do snow etc.
I got the car out last spring and had a new timevalve exhaust put on it did a major spring annual service and drove it home. Stopped maybe 3 times on the way. I back it down the driveway and turn it off. Open garage door and go to start the car and nothing. Could the starter just quit, like that? Any way to test it? Thanks guys- as a new member I appreciate the help!
Ben
1985 16v
· IR MODERATOR
Ben
1985 16v
if its been in storage i would suspect a dead battery. try jump starting it first.
· IR MODERATOR
i would check the starter first
1986 190E 2.3-16v + 2006 CLS55 AMG
what i woud do first is get a wrench and connect positive terminals at the starter, this will bypass the ignition swich and relay. if its good than look for something else!
1 - 13 of 13 Posts
