I have a 92 Mercedes Benz 300E 4 Matic, I cannot trun the iginition on 'P' gear, but when I move to 'N', the car can be turn on normally, what is the problem and how to fix it?
2003 Mercedes Benz E500
Replace...
the neutral safety, or "inhibitor" switch on the side of the automatic transmission. It is something of a pain on this chassis as the clearance between the side of the tranny and the tunnel is pretty tight.
Your profile does not show your location, but the part is around $60 here in the States, and should be less then an hour to install.
Good luck,
JR
