I'm not sure if ths is the part you are looking for but, if you take off the air filter,...
I'm not sure if ths is the part you are looking for but, if you take off the air filter, look behind the fuel distributor, the white piece with all the lil pipes in it. You should see a part, not mounted, but rather stuck between the intake mainfold, and he engien block. It has a lil black wheel on the left end and there is two rubber hoses attached to it for air delivery, turning that wheel will adjust your idle, but it's a very fine adjustment, so do 2-4 turned and see what you get.
