1984 380SL Hardtop/conv.
I have a 1984 380SL. The isle speed when cold and ambient temp at 65-80* is around 700 RPM. After i drive it for a while and the engine warms up it will idle at 1500RPM when placed in park.
Is there an adjustment which can cause this? Where is it and what doe's it look like?
Thanks:confused:
82 380SL 96 SL500 03 SL500
There is no idle speed adjustment on your car. Idle is automatically set by the idle control unit in conjunction with the idle air valve.
If you do a search you'll find numerous thread on the same or similar problems you're experiencing.
