1 - 1 of 1 Posts
Hello again!
I have a question about the idle speed adjuster/control unit. Trying to diagnose first rough idle, now no start. Switched ignition switch on, but no click at idle speed adjuster. Took off adjuster, and it is open. Is that normal? Also, tested for voltage to adjuster, and it was very small, in the mili-volts. What is the normal voltage going to the adjuster? At a loss here, and low on cash. What do you guys think about this?? Bad adjuster because it is open with no voltage, or control unit? Please help a poor boy out.... TERZI
1 - 1 of 1 Posts
