Euro 1989`500 SEC "Buffalo soldiers edition"
What does Idle Control Unit look like? Has anyone picture of it? I've been trying to locate it but can't find. Car is '89 500 euro SEC. Problem is that idle is a little bit rough when engine is it operating temperature. I had just problem that car didn't started anymore. I changed Fuel Pump Relay and now it starts just fine again. I've been trying to measure ohms from Idle Control Valve and it is about 5 ohms. I measured volts also from the ICV connector when ignition was on and it doesn't give any reasonable results. It should be 12V but it is way out of 12 volts. I am planning to buy repair manual so I don't have to guess where all parts locate :)
I hope you understand my english :eek:
