I recently bought a 1986 300 SDL. A light that looks like an upside down light bulb with an exclamation point inside has come on while driving. Any ideas what this light indicates?
Thanks,
1989 420SEL
This is the "Exterior Light Failure" indicator...one of your exterior light bulbs is out, or of the wrong type, or in the process of going out. If it is the brake light or a turn signal, then this light will only come on when applying the brake or using the turn signal.
Depends on the day!
Yup, it has an owners manual on the CD as well:)
If you really get into the DIY an EPC would be helpful.. You can check out my site to see what they're about.
Best of Luck!
Jonathan
