1 - 1 of 1 Posts
94 SL600, 89 Jag XJS conv, 85 Daimler Princess, 97 993 63 Avanti 16 Lincoln MKZ hybrid 16 Silverado
in the engine area between the firewall and cabin filter cover I found a plastic tube ( black ) that was below the wiring bundle that traveled from computer side to the driver's side then had a two tube connector that joined two similar size plastic tubes ( one black the other white ). What does the hose do? and what won't work if it is not connected/ or sealed ?
Where is a simple place to connect with the turn signal system? I have new arrow LED flashers layered under the exterior mirrors and don't want to hassle with the multi block connection above the foot pedal area.
Thank you in advance
1 - 1 of 1 Posts
