1 - 9 of 9 Posts
Folks, I’ve just cleaned my icv on my 1990 560SEL and am replacing the 2 small hoses at the 2 connection points. There’s a small tube, which looks like a vacuum tube that goes between the rubber hoses. Mine appears to be melted closed at one end. Should it be melted closed? I can’t imagine it should be. I’ll try to post an image of the parts 84875F40-E2CF-4B1B-A691-C23EA1E05DF0.jpeg
I have an 89 and had a 91 SEL 560. Both have the hard plastic tube open at both ends. I have seen replacements parts with the tube heat sealed shut.
Great looking vehicle.
I'd be interested in the correct answer to your question if you ever find out about sealed vs open ended.
SuperModerator
This was discussed in a thread with definitive information about which motor requires what, I think by member H.D. However, finding that thread currently with our search facility down may be a challenge.
SuperModerator
The excellent H.D. has found the thread. Post #15 for this info.
Thank you for the kinds words and the info! I will pull it back apart and shave the melted end off the tube. I'm chasing a cold start issue and wanted to try the easier stuff before having gas run into my armpit when replacing the accumulator
By memory that tube is an adjustment for the idle I do believe. You buy one size and then cut it. See if you can find that thread. They all come closed from MB
1 - 9 of 9 Posts
