Thxs for the info ... are there any drawbacks towards the ETC on our trucks with larger tires ?? And also what is the stock crawl ratio for our trucks ?? Thxs again !!Wolfgang - 5/4/2005 2:01 PM
Not much rubbing since the ML was lifted by welding longer bolts to the top of the springs, similar to the ORC kit, but less expensive, the Islandic lift kit. In addition it has a 30 mm bodylift. And the torsion bars at the front cranked up. Islandic folks are rather creative when it comes to such things, have to, when it breaks down in the middle of nowhere, as has happened to me on an Islandic trip. Had to cut new seals for the fuel filter about a days trip away from civilisation.
I dont think the ML crawl ratio needs any adjustment. It has a lot of torque at the wheels already.
Braking and acceleration is slower. ETS works fine, not much difference, or actually improves since the tires stick better. ESP becomes "less intruding". But MB doesn't recommend it, and in some countries has added a protrusion into the wheelwell so no large tires can be used, by design, or unintentional, not sure, so one should check the wheelwells before purchase. [MLOffRoad - 5/4/2005 11:05 AM
Roger that ... thxs again for the information.Wolfgang - 5/4/2005 2:25 PM
Thxs for the info ... are there any drawbacks towards the ETC on our trucks with larger tires ?? And also what is the stock crawl ratio for our trucks ?? Thxs again !!] Crawl ratio is about 38.5:1.
You are welcome. Good luck with your mods, and let us know whne you have new pics. [MLOffRoad - 5/4/2005 1:39 PM
You betcha !! Hopefully some of them will make it onto your website ... [^]Wolfgang - 5/4/2005 6:56 PM
Roger that ... thxs again for the information.]
That's fast compared to 80s G-wagen diesels, who do 30+ seconds on stock tires. Those need to have the gears changed, otherwise it gets difficult. In California the problem is merging onto the highway without sitting there for a couple hours to find a slot.. [EuroCoupe - 5/5/2005 3:16 PM
An ML230 with 35" tires... I would be afraid to make a left hand turn into oncoming traffic if it were less than 1/4 mile away, or in his case, a right hand turn. Probably does 0-60 in 18-20 seconds.
Yes. 38" is about standard for an Icelandic winter car.chia - 5/5/2005 4:37 PM
Those are pretty puny tires for an Iceland rig! []
I was expecting some 44" rubbers on rims with about 20 inches of offset and the quarter panels and fenders completely SawZall'd away. [8D]
Naw, but that is pretty sweet for an ML. I've been considering a 1" body lift for some time, but I've been too lazy to really get into it. Eventually I hope to put some Dana 44's or maybe even some Unimog 404's under the ML, and run 35" or 37" tires.
