1 - 10 of 10 Posts
E550W4
I was told that the V8 transmissions tend to last longer than the I6 because the V8s rarely rev that high. On my 400E, unless in a moment of stop light anger, my RPMs rarely get above 2,500-3,000 rpm.
Any truth to this theory?
1996, A124, E320 Sportline Cabriolet x 2
More revs = less torque for same power, torque kills transmissions.........
Yup, torque is the enemy of transmissions. As an example, Brabus detunes some of their engines to prevent torque from destroying the transmissions.
I don't think even the Honda boys have to worry about killing the trans when VTEC kicks in and revs to 7-8K on the dial (a.k.a all noise, no torque)
Depends on how well these transmissions deal with RPM, but the Engineering principal (relating to loading, speed and power) remains. Certainly RPM is no problem with mine!!
E550W4
Is the 400E/E420/500E transmission any more robust than the other W124 transmissions?
1995 E320 Cabriolet, 2007 E350 Sport P2, 1995 E420
I bought my E420 with about 60K miles and saw the receipts for reverse having been rebuilt, not sure if that is an anomaly.
Cruise Control
'87 300TD/'90 300D/'94 Quattro/'89 Vanagon TDI/'01 EV Weekender VR6
Other than the bellhousing sections, I'm not sure the guts of the 722.3 are much different between the 6 and 8 cylinders
Cruise Control
I think those changes can be added to any 722.3 trans. If my memory serves, the used trans I bought for my project wagon was rebuilt with kevlar clutch packs intended for R129 V12 models.
1 - 10 of 10 Posts
