1 - 17 of 17 Posts
w126 420 sel
so i am heading back from the so cal meet which was pretty cool. there were a lot more benzes there. so anyway, the car was running nice and strong until i was close to my exit. i noticed i was going 45mph on the freeway, so i pressed on the pedal for speed. the car felt like it was slipping or something, i turned on my hazards and gradually slowed down. then i hear one hard knock sound. i ended up rolling to a stop in the middle of the intersection. i kept revving the engine which somewhat help me finally roll to the side of the road. the car was finally towed home.[B)]
do these symptoms lead to the transmission? the car now has 175,000+ miles. is that an average life span for w126 transmissions?
1991 300 SE
No. I got 220,000 or so on an original tranny – a bunch more on the 300 D. You didn’t just blow an oil line or something? That happened to me, lost all my ATF and had to have her towed. Usually they don’t just go like that – when was the last service?
81' 300SD, 82' 300D
Properly cared for MB trannys can last for 300K mi+. Try this before you start looking for a new or rebuilt tranny. Put a some trans-x in the tranny, and try shifting it through the gears. It may take a while, but if it works, drive it for a few hours, making sure to shift through the gears a lot. I heard that reversing it often will be well. After that, change the fluid, filter, drain the converter also. Put new proper fluid in, as well as a new filter, and new gasket too. That might help.
-Joe
w126 420 sel
can you explain the hard one time knock sound, either way, transmission or not, i think we are going to have the transmission replaced.
I Went to my mechanic to have my transmission fulid changed he said that It would be a bad idea showing me the bolts on the transmission and how they have never been removed since there was no tread marks, a car with as many miles as mine 144000 changing the fulid may cause sliping. should I do it anyway?? and what is this filter converter and gasket that you mentioned??
Moderator
Mercedes
My sympathies... its not the flex disk? I have no clue what could cause a "one time knock". Where did the sound come from, front or rear?
1991 300 SE
Mark420 - 2/6/2005 1:03 PM
The torque converter has its own drain plug, the filer keeps the fluid clean the gasket is between the transmission housing and the lower pan. Are you saying with almost 115,000 miles your car has never had the ATF changed? I guess the mechanic thinks the internal parts are being held together by varnish and sludge. I find that hare to believe. I hope it’s not true. How’s the tranny working now?
85 300 SD
i know what can cause a one-time knock...a B2 piston...go to * and click on "articles"...then look for B2 in the transmission section....read the symptoms carefully, and if your car exhibits them, you can be back on the road for around $200...i just replaced mine and it runs like new...
you have got to be kidding me...i cant write a websites address in a post??? anyhow the website is M B Zdot org
Moderator
1991 500SEC Euro, 1987 560SEC Federal
Hi 85DRTY,
Good info, i just dragged & dropped the URL, and then couldn't get the transmission ONLY to display, and like you, anything else for that matter.
MBL
You're local so try these guys. I had mine exchanged there about three years ago and it has been sweet since.
They also have some great information on troubleshooting the MB trans. Also for the Diesel guys.
www.mercedesdismantlers.com
These guys also do the rebuilds for most of the other resellers.
Ciao, Brian
86 560SEL
After driving mine with a slipping, leaking and sometimes stucked in gear tranny for almost a year, I replaced mine with a rebuilt. At least I don't have to worry about being stuck somewhere or nowhere. Everytime when changing fluid from the old tranny, there always some debris coming out. Guess something inside were breaking apart.
The only thing is that it kicks hard from first gear to second, and that about it I do have this problem however, it wont go past 80mph I was told that it is a clogged cat do you think that the fact that none of those things you mentioned have never been replaced or changed have anything to do with it?
SLK55 (2006) C36 (1995)
sunvalley
Yeah, i had my tranny done at the same shop, they fulfilled the warranty too, but they left my car parked outside overnight!!! I won't be going back.
W-1-2-3 Go!
blue420sel - 2/5/2005 9:05 PM
I'm glad nobody hit you![:0]
Cyberdakon, your SEC is lovely! That grille is such a nice touch [;)] Wish I came earlier so I could have seen your car opened up, I came 30 minutes late.[:(]
Thanks, you should have asked karugs!, i would have done it for you!
i think i saw your car, you had the hood up right? Looks awesome! i have a picture of it!
W-1-2-3 Go!
Thanks man! But I didn't want to be rude and just ask you out of the blue. Next meet (I think there'll be another one in March) I'll make sure to check yours out some more!
Yup, Doug (Citron) told me to pop the hood as he's already seen it before at the August 2004 meet. Thanks, I wish I took pics myself!
1 - 17 of 17 Posts
