Yep, I've had an OEM COMAND installed in my CLK for under $1500 including ALL mercedes par...
Yep, I've had an OEM COMAND installed in my CLK for under $1500 including ALL mercedes parts. The wiring harnesses were retrofitted with the appropriate MB connectors, and the antennea is not located in the rear window. On 00+ models it's the small antenna on the roof used for tele-aid positioning, and an OEM MB splitter is used to tap into that signal for COMAND. On pre-00 cars, the COMAND was never an option so there is no antenna - it must be added and is not hard or expensive to do. Also, I have all the euro only options on my COMAND such as the AUX input in the glove box (perfect for connecting an iPod), RDS, TV button, and British female guide voice (very james bond). Furthermore the system completely integrates with my steering wheel controls, CD changer, tele-aid, would work with the OEM mercedes phone if I had one, and the driving directions appear in my instrument cluster. None of it is "OEM compatible" every part is OEM and the install was factory quality.
Steve (
[email protected]) is the guy who does all the installs and does many other factory retrofits and euro only options. He's already added heated seats to my car, Euro OEM xenons, and several other things. Next up is the OEM Mercedes parktronic system that was never offered as an option in the states :0)
