Hi Guys,
I need some help.
I am now having problems measuring the oil level in my 2002 CLK55 AMG. I believe the dipstick was moved/modified to accommodate the S/C. It no longer reads accurately.
Part of the installation procedure for the S/C I had installed was to relocate the dipstick.
I had the oil changed the very next day after the S/C was removed. Monday I was doing routine cleaning, and decided to check the oil level. It was low so I added a quart. It was still low so I added another quart. I left it at ½ a quart low. Well now I get a message that the oil level is too high. But the dipstick reads ½ quart low.
I need to get a picture of the engine bay of a 2002 CLK55 AMG. Specifically I need a close up picture of the right (Passenger side) front section. (From the center of the engine to the right header),
I need to verify the location of the dipstick.
Also need to know the length of the dipstick. If some one could measure there dipstick from the end to the base/sealing surface of the pull handle. (I’m serious here, I don’t need any personal information)
I need this really soon so I can verify that the dipstick is accurate before I blow a seal due to over filling.
Thanks in advance,
Tim
I need some help.
Thanks in advance,
Tim
