CLK 320
the wheels are brabus monoblock v 18X8.5 with an offset ET 40 . will they fit on my CLK
BenzWorld Tire & Wheel God
I do not know all of the Brabus specs but, it sounds right and does have an offset that ...
I do not know all of the Brabus specs but, it sounds right and does have an offset that should work
CLK55/G500/E55/ML55/etc.
Based on my CLK55, you will probably need a spacer on front. ET40 puts the edge of the rim REALLY close to the steering knuckle. ET35 gives it enough clearance, so a 5mm spacer would be OK.
-s-
