2004 clk500
Its my fault, i disconnected the battery cable trying to reset a cel but i forgot my trunk key will only go half way in, so i am so out of luck. i can get into the cabin or open the hood. i read a post saying that you can jump the trunk open by connecting a couple of wires. any info will be helpful. thanks..
2001 CLK55 AMG, 2002 C32 AMG
well, if you cant get the key into the hole, you could hook another car up to your car in the engine bay to supply power to it. then, you can press the central unlock in your car and then walk around to the back and press the button to open it. it has been discussed recently here on the forum but i dont have the thread saved. do a search.
2004 clk500
can anyone help me find that thread, thanks for the reply.
i just bought some pb penetrating catalyst spray. the lock had been like that since we bought it, about 5 years so i dont think its going to work. I just sprayed it, i am going to wait a few minutes and try to unlock with key.
the battery hook up seems like a great idea only if i know which wires to hook up. thanks.
*is this the thread you were referring to: http://www.benzworld.org/forums/w202-c-class/1416687-dead-battery-open-boot.html
i found it, Thanks a million.
http://www.benzguide.com/index.php?title=Shut_the_Trunk_on_a_Disconnect_Battery
2004 clk500
Discussion Starter · #5 ·
yes. that was the thread. the positive goes on the wires in the black box and the ground can go on any chassis ground. good luck. let us know how the results turn out.
Thanks i got everything power up and pop the trunk. somehow on my 1998 c230 tapping the + battery cable there didn't do anything which is fuse #4. I tried it on Fuse #8 the 30amp fuse and everything power up, the cluster, interior lights, everything. I was really happy to get power and open the trunk otherwise i wouldn't know what else to do. Thanks again. :)
Hey guys. The same thing just happened to me. I disconnected the battery then closed the truck. The next day I went to reconnect and reprogram my windows, and I couldn't get the truck open (key didn't turn the lock either). I read this post, used my second car to connect two wires under the hood (just like the picture), and popped the trunk right open!
For my next trick, I'm going to disassemble the truck lock and clean it out.
These forums are great! Thanks everyone!
