1 - 13 of 13 Posts
I usually use regular rim cleaner from AutoZone, and i scrub for a looong time. Any better ideas with better results? What do you all use? Btw, this is my favorite benz forum out of mercedesshop, and mercedesforum. Thanks!
ROd-ALi
I think you guyz call them 15 holes for my 86 and 91. But i was also wondering about my 81. Cant leave him behind. Heres a pic
Thanks so much
ROd-ALi
1991 300 SE
No, with the bundt rims and to a lesser degree the 15 hole, just hard scrubbing. I use what looks like a large bottle washing brush to clean.
1990 300SE
I use Eagle One A2Z. It's amazing stuff. But you still have to clean each hole individually. I use a toothbrush and a sponge, cut in half length wise to fit into the holes. Here are some results:
Before:
After:
380SEC EURO
danwatt - 4/30/2005 4:53 PM
After:
Great results. I use a similar application (toothbrush and sponge) when cleaning my 15-hole rims. It’s such a laborious task, though!
AMG Forums Moderator
SLK55 (2006) C36 (1995)
or buy simpler rims. i clean mine with 6 swipes. once for each spoke, and once all around.
Depends on the day!
Indeed, cleaning the AMG's is a dream compared to the 15 hole buggers.. Although the 15 holers pale in comparision to cleaning wire wheels on the Healey..to get those CLEAN it's an hour a wheel w/ a few different tooth brushes and a LOT Of Q tips.
Jonathan
Discussion Starter #12
hey where can i find this eagle A2Z stuff, and what is the process of cleaning them? THanks for all help!
ROd-ALi
1994 W124 E320 1997W140 S320(RIP),1993W140300SE(RIP),2000W208CLK320(RIP) , 1993 W201 190E 2.6 (RIP),
erfaniman - 4/29/2005 8:10 PM
ROd-ALi
Here's what I started using after a sumer stint with a cleaning company. On the metal tops of the water fontains we used this dtuff called Deep Luster Stainless Steel Foam Cleaner. The stuff was amazing, strong, yet gently, and got tough dirty out of the way, PLUS left a deep lasting luster. PERFECT. I quit long ago, but never forgot that stuff. I finally got around to going to the cleaning place and buying can of it to clean our rims. Just go to your local cleaning supply house, the places that actually stock JANITORS, and ask for whatever the use as a stainles steel cleaner.[;)]
1 - 13 of 13 Posts
