1 - 17 of 17 Posts
1994 Mercedes S500 Limo
My S500 is killing me financially, not for repairs or anything as its doing well, but my god the fuel is a nightmare, im getting 240 miles from a tank thats costing £95 $185 to fill, this seems to be every 10 days and sometimes 5 times a month £480 $940 a month is a lot to find.
It needs to go but i cant bear to part, i work for a garage and have driven many a possible replacement but nothing feels right, im stuck for what to do.
89 964c4, 69 xke, 74.5 jensen, 02 bmw 325i, 93 600sel, 99 f-350
dude... just park it and get a cheap daily driver... enjoy the w140 on weekends with your lady...
1997 S 500
I'm confused
So you're only seeing 240 miles/tank? With a 26.4 gallon tank (100liters) that's ~9 miles per gallon. The worst I've seen in my 97 is ~15mpg with a lot of city driving.
93 500SEL & 99 S500
My 500SEL has been getting around 12 - 13 MPG in stop and go traffic. Sometimes it's as low as 7mpg for some periods!
Current 1992 - 500SEL, W124 - 1989 230E (sold)
ohh yeh :) that is realy dreadful but blame oil companies not your M119 engine. Fortunately for me 500 is my sunday car and i ride my suzuki to work everyday and that gives me around 50+ mpg (depends how much i trash it sometimes even more) so week of fuel to work is around 15 NZD (about 12USD) ....maybe get a nice motorbike for your work and keep 500 as fun car. surely works for me for past 3 years
1994 S420
I get ~13.5 MPH in my S420 but I pin it a lot because I enjoy the speed as well. When I drive economically I get about 15 or so...1.5 MPG is not worth turtling around in my opinion so I'll settle for 13.5 and have more fun driving.
I fill up 3-4 times per month for like $90 a pop, always right before or at the fuel light, getting like 230-240 miles before each fill up.
EDIT~Highway mileage is consistently above 15 MPG, that was in town, and I gun it on the freeway a lot
1979 240 D, 1993 500 SEL
I heard Bobby Likis, who has a car talk show on Saturdays, advise that you can get up to twenty percent better mileage in stop and go traffic if you manually shift the automatic-ie from position 1, to 3 and then to drive.Makes sense, since starting from a stop in drive position is not as efficient.
The other way I deal with the gas is to drive my 240d manual shift during the week and the S class on the weekend.You definitely need a daily driver car.
OR you could get FGSS for around $150 and have your car always start in 1st gear and wont have to replace gear shift linkage etc. in 3 months or so :)
Discussion Starter · #10 ·
its my fault as i live only 2 miles from work so it never gets chance to warm up, plus im always running late so i cane it, (plus it sounds so good and makes people look around) 240 miles is a worse case senario, ive just had 380 miles from a tank doing some long distance coastal runs, and that included a weeks worth of work and backs, so i think i could see maybe 450 on a solid run, like i said maintence costs so far have not been a problem but the fuel has. Im jus glad i dont have to driveit into the center of london.
Banned
99 Merc S420 (80k Mi) 07 Lexus LS460 (21k Miles)
Get an S320 or step down to an E320.
1996 S320 (Kuro) 1998 S600 (Weiss)
The 320 wasn't a very popular model in Japan (since everyone was loaded in the 90's I guess) so when I was searching for my current W140 it was quite hard to find a decent 320 with more options than a cardboard box - along the way the dealerships attempted to push me for a 500 going on about "the milage isn't that much different to a 320" etc. Pricks - like hell it isn't - I'm glad I stuck to my guns and went with the 320 now that gas prices have gone through the roof here...
current fleet: 1996 s500; 1997 BMW 328ic; 2000 Nissan Frontier; 1966 AC Cobra
Chances are you are experiencing poor mileage because your fuel is laced with ethanol.
The following companies are lacing all grades with ethanol:
BP
Shell
maybe others
Ethanol has only 70% of the btu's of gasoline which translates into:
less power
poorer mpg
rough idle
starting problems
corrosion of internal steel, aluminum, plastic and rubber parts
Check out the thread on "ethanol is a joke and should be avioded"
Ed in SC
W639 Vito 110 CDI; Ponton 220S; VW Phaeton V10 tdi; 1995 S500 ex diplomatic car (gone)
95 octane here and no mention of ethanol
Ethanol has an ocatane rating greater than gasoline.
In the US they are allowed to blend up to 10% ethanol and still label it gasoline.
This allows the oil companies to downgrade the octane on the 90% and keep the overall ocatane rating the same. So again, you get a poor quality fuel that has all the negative characteristics.
In your 95 octane fuel you can still have 10% ethanol which will cause you problems.
Ed in SC
1996 S500 coupe
jesus.. that's a lotta $ on fuel
I don't think I have ever gotten less than 19 MPG in my coupe
(19 US MPG is 22.8 British MPG or approx 12.4L/100km .. I have gotten as little as 11.5L/100 in the past with 75% hwy/25% city)
... that's a mix of some hwy, some city
I use Shell 91, and at the pumps, it's clearly labeled that it does not contain Ethanol. Although lesses grades (87 & 89) do contain Ethanol, but it gives me poorer mileage
Miloking, what is FGSS? sounds like you are saying that manually shifting the automatic is not a good idea.If that is true,I don't want to do it and wreck the tranny, would rather just pay the gas bill.
1 - 17 of 17 Posts
