I know that theres a button that allows you to change the setting from Fahrenheit and Celsius and vice versa. I just can't recall which button at the moment.i have a question, do guys know how to switch my climate control between Fahrenheit and Celsius?
Yes, thats true for >1997 models, that will get C or F setting from the instrumentYou are going to have to have the climate control reflashed. Meaning, someone with a Star Diagnostic machine has to change the settings with their computer. The only way.
I have used your information posted on TekInfo to change the temperature display from fahrenheit to celsius, and it works well;BUT ever since i di this change, the Back Light of the Climate Control Unit does not work when i turn on the lights. The interesting thing is that when the ignition is off and i press the REST button, the unit turns on and so does the Backlight. What could be the problem ? Do i need to reprogram something on the Climate Control Unit ?Yes, thats true for >1997 models, that will get C or F setting from the instrument
cluster, but in this case, it can be done on the control unit;
STAR TekInfo
br,
syljua
