1 - 9 of 9 Posts
1992 190e 2.6L, automatic, 125,000
I can't figure it out... my windshield wipers just quit working, and yesterday i figured out my rear defrost and cruise control don't work i checked the fuses all are good any help? suggestions? anything? thanks:confused:
96 C36, 87 Turbo'd 190E 2.3-16, 86 SC'd 190E 2.3-16, Brabus'd C32
ahhhh the usual. get a new wiper motor, and who needs the other two anyways
'92 MB W201 2.3, '10 MB X164 GL550 4Matic, '14 MB W218 CLS550 4Matic
Fuse #20 is designated for the Wipers and the Optical Horn, if your horn works then your wiper motor is gone
BUT
See if your washer nozzles works if they are, try to listen to the noise the wiper motor makes, if it does then you need to grease the mechanism with a bit of petrolium jelly
I would check the fuses first a hair crack may avoid the current from passing through, also oxides on the fuse contacts and humidity if any
got the same problem lost both wipers and defrost while driving in a snow storm, fun times...
anyways checked fuses and swapped in a known good combination relay since that relay controls both and seemed the most logical place to start but still doesnt work.
figured it out was the combination relay
· IR MODERATOR
1996 Volvo 855GLT, 1993 MB 190e 2.3 8v, 1998 Subaru Outback SUS, 1991 BMW 525, 1998 MB C230
bad fuses, they may look good but they may be corroded on the ends causing thingd not to work.
1991 190e 2.6 automatic
like the poster before said, the fuses migth look intact but the best thing is to just replace them with new ones and make sure they are clamped in nice on both ends and are touching the metal
1 - 9 of 9 Posts
