1 - 11 of 11 Posts
'02 C230 Sport Coupe
The 2003 C230 *1.8* Liter Kompressor Sport Coupe...
*ugh* Then just call it a C 180 K...They have 'em in Germany, y'know... *Grumble* Why make the engine smaller?? It makes no sense!
Member
'00 ML320 Elegance
It's different...
The new direction injection supercharged 4 cylinder engines are all 1.8L for now. They do have a C180K in Germany, but it has a different kind of 1.8L engine (a lot less powerful).
Bleh...
I still say it's an injustice.
Weaker engine, same price...*sigh*
2015 ML250 BTC
BMW's 330 actually is 3L
MB's new engine option next year for MLs-- ML350-- it will be 3.7L.
W203 200 Kompressor
Re: It's different...
Are you sure about this? I was almost certain that it was the very same engine (but with different engine software)
Member
'00 ML320 Elegance
Not necessarily so...
While there may be slightly less horsepower and slightly less torque, the engine is also far smoother, more fuel efficient, and much cleaner. The 0-62mph times only drop by 0.1 seconds (in other words, no change whatsoever).
Member
'00 ML320 Elegance
Yes...
It's a completely different engine. Aluminum alloy instead of the old steel block.
W203 200 Kompressor
Re: Yes...
Ohh a slight misunderstanding from my side...
Ok, what I was referring to was the "old" C180. As far as I know there havn't been any supercharged C180"K" based on the old M111-engine. The "old" C180 had the same 2 litre engine-block as the "old" C200K but was naturally aspirated.
2015 ML250 BTC
4 valves per cylinder
the latest model is not the 3 valves with twin spark arrangement.
1 - 11 of 11 Posts
