2001 E320 and a 2001 E320 Wagon
I bought a 2001 e320 base wagon several months ago and I have repaired or maintained most everything suggested on this site. Tranny fluid, wheel bearings, a few minor oil leaks, cats. Well I really like the wagon, a lot. I also bought a 2001 e320 4 door..
But I digress, I would like to install factory AMG wheels on my wagon and I have found a couple of sets for sale. So will they fit my base wagon without creating a bunch of issues, like rubbing the rear quarters or affecting the the rear hydraulics or big camber issues ?
They are original AMG wheels and these are the specs on em
front-- 18x8.5 tire--- 245/45/18
rear--- 18x9.5 tire--- 275/40/18
would I need to swap tire size for the wagon ?
Thanks for any help or pics you may give..
'07 GL320CDI
The recent wheel catalog shows one AMG wheelset (Style II) in 18-in size for W210.
B6 603 1007 8JX18 ET31 235/40-18
B6 603 1001 9JX18 ET35 265/35-18
Both are labled "modification of bodywork necessary."
Yours are larger.
No difference between sedan and wagon.
thanks for the reply, I will assume the two sets I am looking at will not be a great deal if I need different tires so I will continue the search for what I need. I will check the wheels to make sure of part numbers to, thanks for the info. Oh am I to assume the bodywork would be rolled fenders or something like that ?
2000 e320 4matic
i've run 17 x 8 1/2 et 30 amg aeros on my wagon with no problems. if that helps.
