Hear goes my sprinter cut out on the motorway 2 nights ago so i called out merc roadside, anyway he came and got me going again the cdi wiring loom had rubbed and blown a fuse and a relay so he repaired aprox 6 wires and i was on my way again he gave me 3 fuses in case it blew again which the day after it did so i replaced the fuse but after a few miles it blew again trying to get home i replaced the fuse a few times using the fuses he gave me and then using fuses from different things i thought i may not need wipers etc. anyway after a few stops i decided to put a piece of wire round the fuse (i know very stupid of me) to try to get me home so after turning the engine over a few times i noticed smoke coming from under my glove box so i sopped and called a recovery truck to get me to a garrage just wondering what sort of damage i may have done Thanks.
Buy the way it is a 55 plate 313 cdi and thanks in advance for any replys
You have Burnt the ECU out!
The camshaft sensor wire on the rocker cover has most probably been rubbing and thats what was causing you short circuit!
new ECU time - Be sure to look on ebay - A specialist on the called sprinter-cdi can help!
