can anyone tell me where the hydraulic pump is on my mog and what it looks like.i put on a winch and rigged it up to the hydraulic box but nothing happens.mine is a 1969 ,416 doka.
:surrender:thanks
It sound like you have hooked your winch into the quick disconnects? The hydraulic pump for the valve body should be directly below the the crank pulley. It's squarish with a round pulley and two hose connections ;) You can just see the pulley below the rad when standing in front of the truck.
It may also be that the controls below the steering wheel are locked. The ignition key operates a lock mechanism in the center of the lever mounting to prevent accidental operation as driving.
