My car has a leak from the main hydraulic pump on the right hand side of the trunk.
The goldish bronzish bolt is cracked on mine? could that be the one that is leaking? well that is the source of my small leak... can the bolts be replaced? I tried tightening them... may have messed the goldish one in the process...
!!! AHH
and my headliner is starting to wrinkle a bit too but not so bad yet.....
Hmm I was thinking if there was any kind of product like adhesive or glue or something that i can just put around the bolts here to stop the leak?
Some Kinda EPOXY?
So since we have found the source of the leak... if we figure out the plan for action in regards this could save people a bundle... cuz new pumps are $400.00!
This is a perfect canadate for JB Weld regular. I have rebuilt the sides of small engines,5hp (the oil crankcase) and never a leak! If leak is from around bolt can't hurt to try it. It takes pressure and heat extremely well..
You might have to replace the cylinder. I just recently got the same problem. Some oil ate away at my headliner first, then my top got stuck going back. I'm taking it to a mechanic tomm.
Sightless,
Make sure that you have clean surface for bonding (the treads on bolts & block). No oil (hydraulic fluid), etc, etc! Otherwise, you just wasted your time thinking it's not working Also there are 2 kind of locktite (blue & red), and one is for permanent application (I forgot which one is which).
The bolts maybe able to be replaced, but they maybe specialty bolts (hard to find). The bronze, maybe a machined allen bolts (I'm not positive, but looks like it).
I am having a similar issue. I heard a noise when doing a right sharp turn and then had to check the steering fluid levels. Down to the min sign. I checked the garage space and I have been leaking tiny amounts on the ground. GRRR. I will put it on the stands tomorrow morning and hopefully see where the leak is coming from
That suxes! I did a quick search and it seems many have similar issue. I wonder whether this is something we are doing with slamming the wheel at full lock by mistake or going over humps too quickly... not sure. :crybaby2:
Glad I could help. We southern boys can't afford to buy M/B parts willy nilly!
Related Threads
Mercedes-Benz Forum
7.6M posts
693.6K members
Since 1999
