1 - 8 of 8 Posts
82 300SD fiwer, 83 300SD parts car, for now...
On my 1982 300sd I can't get the vent to move to the heat position, only defrost, a bit of searching hasn't turned up any obvious culprits and I don't want to jump in blind, can anyone give me some pointers here? Is this vacuum operated?
2012 CL550 4MATIC Coupe
Defrost is the default for total vacuum failure to the HVAC - because the car is still safe to drive that way.
+1 Read my repair and DIY Thread.
1985 300sd
welcome to my world, i just had the same problem with my '85sd. there are various things that can cause this, most likely a vacuum leak. from one of your vacuum actuators, switchover valves, or vacuum lines.mine was a bad actuator for the center vents leaking. i disconnected it plugged the line and all the other functions worked properly. you'll need a vacuum pump to check them with. i'll check back with you later gotta go to work!
Thanks for the replies, can anyone tell me where the vacuum lines come out under the hood? I changed the engine and think I got everything back where it belongs, but that may be a good start.
1983 300SD
On my car the defrost works but not enough heat coming out through the vents, could it be the same problem? I have changed the climate control twice, but didn't make any difference.Where do I start?
1 - 8 of 8 Posts
