I've had an ASR limp mode for a while, and I replaced the electronic throttle assembly (ETA) from a known good car that was fully serviced for the eco wiring harness.
After replacing, initially I was out of the ASR limp mode, but under acceleration, the throttle hunts as if it has a massive vacuum leak. The car can be driven with the hunting/surging throttle but only at about 5mph.
I re-checked all of the vacuum connections I made (new MAF to TB coupler with clamps), new crankcase vent hose (part closest to the TB; other 2 sections not yet installed - existing hoses in apparently serviceable condition). I checked for vac leaks by spraying with starter fluid. Nothing obvious.
After re-installing the ETA to double check vacuum lines, ASR AND ABS lights are now on again.
Blinker code reader blinks 30 on pin 6 - indicates "CAN data bus to EA/CC/ISC control module (N4/1) interrupted"
I have previously had this error but it went away after re-seating the EA/CC/ISC (EGAS) module.
STAR diagnostic computer is in the mail from china, ordered several weeks ago.
I have checked all vacuum hoses, tried to detect a vacuum leak by spraying starter fluid around suspect parts, and checked all the pins on all the electrical connectors. The return spring for the throttle linkage is properly installed. I adjusted the throttle cable linkage per attached WIS manual so that there is just enough tension to take the new ETA to WOT position.
I think either:
EGAS module is bad (I believe this car had a bad ETA, which can short and damage the EGAS module)
Discrepancy with length adjustment on the throttle linkage?
Some sort of WOT calibration procedure which I don't understand? codes making me crazy!!
I think either:
I believe I have a good EGAS module from my parts car, but I don't want to swap it in and destroy it if the ETA is bad (below)
"Known good" ETA could have still had eco wires? Which broke after all the manhandling when I swapped and removed/reinstalled to re-check all vacuum linesDiscrepancy with length adjustment on the throttle linkage?
The above seems to just say to push the gas pedal down to the kickdown switch with the engine off, key in the on position - I did, it doesn't seem to do anything.
If anybody has any advice or had a similar issue, let me know. It really seems like a vacuum leak; I simply just can't see anything I could have damaged.Attachments
