2002 CLK55 AMG
Available now is a used HPS 1st generation bolt-on supercharger system for only $2,995 plus UPS shipping. This kit comes as pictured and has been installed on a vehicle yet with all the custom machined pieces amazing quality fit and finishes from HPS aerospace engineers. This product has been on the market for over 14 years and be sold to 200 satisfied customers in 20 different countries worldwide. The product has a proven tracking recorder for success and reliability. If you decide to purchase this unit, HPS will provide a detailed installation guide line and technical support if necessary.
The HPS supercharger system uses a Roots-type compressor that maximizes supercharger power and efficiency. Roots-type superchargers produce high output at low levels of boost, and at low engine speeds, to eliminate supercharger lag. This also increases engine torque and horsepower throughout the entire engine speed range to redline. A proprietary mechanical and digital computerized fuel management control system is included to optimize engine performance, and flawlessly interfaces with the OEM computer systems.
All HPS systems components meet or exceed Mercedes-Benz's own high standards. Factory appearance and quality, high reliability, and quiet operation - all are hallmarks of HPS engineering.
WHATS INCLUDED: EATON MAGNUSON MP90 SUPERCHARGER SYSTEM, 2.275 PULLEY, IDLER PULLEY, ADAPTER 'A', SPACER, MOUNTING PLATE, STUD BOLTS, MOUNTING BRACKET - VAC SOL. CSTG, SUPERCHARGER MOUNT, DISCHARGE PLENUM, INTAKE MFD, INLET PLENUM ASSY, INLET PLENUM BODY, INLET PLENUM THROTTLE BDY, SS FUEL MANAGEMENT DEVICE, CAM COVER BREATHER HOSE, WATER TANK SUPPLY HOSE, TRANSITION HOSE, CONNECTOR HOSE MAF/AIR, DRIVE BELT, BAND CLAMPS, WIRING, ARB CERTIFICATION EO LABEL.
You need to purchase a Fuel Regulator, Bolts & Nuts, Air filter, and a few minor parts.
Note: This supercharger system fits for the 1998-2002 C43, E430, E430 4-Matic, E55, CLK430, CLK55, ML430, and ML55.
2002 CLK55 AMG
How many hp increase do you have with this supercharger??
Best regards
Hello WesleyManley,
The supercharger system will generate up to 100 horsepower & foot pounds of torque gain, all at the low and middle RPM band range. This system generates immediate throttle response, power, and performance. The vehicle will not experience any engine or turbo lag.
