Thoughts :confused: runs about $200
SUN Hyper Voltage System GT
The new Hyper Voltage GT System is designed to stabilize voltage in your vehicle for maximum battery efficiency, allowing its full potential to be released. H.V.S. GT Version provides both function and stylish appearance; units are designed to universal to fit any vehicle, with mounting brackets and one (1) additional grounding cables.
Benefits
•Multi-Range Rev. Performance
(Low-Mid-High)
•Increased horsepower
•Increased torque
•Increased throttle response
•Improved fuel efficiency
•Brighter headlight
•Reduced audio noise
•Improved battery efficiency
•Longer battery life
•Best to works with optional Hyper Ground Wire System
Hyper Voltage System GT Benefits
Sun Automobile Performance Prodcuts
I am very dubious about the benefits claimed here....
All MB components are designed to allow for the fluctuations in voltage that are tolerated from the voltage control regulator.
How this item can improve battery efficiency, horsepower and torque is a mystery. Can you explain?
