1997 C280; brilliant silver originally, now has gold tint, black leather seats, AMG accent
I need a bit of help on how to secure the driver side grill piece, the inboard side attachment is broken. This is the small ~8" widex3" high plastic grill next to the opening at the bottom of the bumper. I'd like to secure it before it falls off especially when a new one probably costs $1,000. :D
1962 W111 220SE Coupe
Not sure I fully understood your situation but if you mean the original attachment point is broken and if it used a screw you can try using a slightly larger diameter screw if the old one has stripped out. If you need a quick fix try an epoxy that you mix both parts and attach that way. I doubt the insert is terribly expensive at the dealer so may be worth at least asking for a quote, sometimes (rarely) you get surprised. Good luck or take a shot from below with a flashlight if I'm way off base and maybe we can better assist.
Thank you for the suggestion, but since the grill is vertical I might have a problem holding it in place while the epoxy dries. What I did was to use some Super Hot Stuff on the bumper side and sprayed the grill with a quick activator. That way I could hold it with my hand for 30 seconds and it will never come off...unless you break it apart. BTW, it was the grill with the temperature sensor between the fins.
