My 2002 E320 4matic wagon recently lost a lot of transmission fluid due to a leak in a rusted line. After replacing the line, I added too much fluid. I am attempting to siphon out the excess using a long, thin and perfectly clean plastic hose inserted into the dipstick tube. I let the car idle until the trans fluid is above 20C. This makes the level high on the dipstick, thus the inserted end of my hose should be in the fluid. I inserted the hose all the way into the dipstick tube until it bottomed out. But when I suck on the hose, all I get is (foul tasting) air.
How can I remove the excess fluid from the transmission? Should unscrew one of the lines I replaced and let it drain? Would I need to turn the car on with that line open, or would that simply cause tons of fluid to spray everywhere?
Yeah, considering how much time I've spent on this one leaking fluid line, I should have just taken this problem to the shop.
