Everything on the Benz is metric. that fuel line is probably 8mm... 8mm tubing is as close to 5/16" as don't matter, only the threads are different.
You could use that hole for the ejector seat switch:eekonly other annoying part is that there's the hole for the clock control in the plastic cover.. but like I said, I'm happy with the results. function > form.
With that emergency cover which flips to show the NOS button :devilactually, the NOS button should be a big red button on the center console, near the shifter.
Yes they do! They make a couple different font styles. I looked briefly last night to try and find something close to the other gauges, and found one. Just waiting to hear back from the manufacturer about density of the stock.Nice work on the gauges. I'm pretty sure there is an aftermarket white gauge face available so that way they would all be the same color.
